C1 Upper A Frame Pivot Shaft - NCRS Discussion Boards
  • Jerry Clark
    I would like to know if anyone can identify the thread size on the upper A Frame pivot / cross haft. I need to jamb nut this shaft but nothing seems to fit.
    As always, I appreciate the help
    jer
  • Jim38243
    Re: C1 Upper A Frame Pivot Shaft
    I know for a 1965 it is a 7/16" 20 fine thread (not a 14) and I believe it is the same for all c2's.
    • Jerry Clark
      way larger on C1 Jim, they appear to be in the .780 range however;
      I understand Corvette America, (the customers source for this part), are selling incorrect reproduction replacement shafts. The repros are threaded the same on both ends and herein lies the problem.
      jer
      • Kris Schmalenberg
        What thread are you after. The inner one or the outer bushing thread. The outer is .750 but is an odd pitch. I think it is 10 TPI
