C2 front suspension parts availability - NCRS Discussion Boards
  • Neil L.
    • February 1, 1997
    • 44
    Are the front stabilizer bar grommets, p/n 3776814 and front shock grommets
    p/n 3708378 still available under different p/n's?
    • 43238
    Re: C2 front suspension parts availability
    Neil----
    GM #3776814 is a part number which "does not compute"; I can't find any record of it having ever existed. That's not to say, for sure, that it didn't, but I can't find any record of it.
    GM #3708378 went through a whole bunch of supercessive iterations. For the last 20 years and currently, it's known as GM #6270752 and GM lists for about $1.25/each.
    • Neil L.
      • February 1, 1997
      • 44
      Joe Lucia one more p/n please.
      Joe, Do you have a good part number for the front stabilizer bar grommets, 4 on each side. I got the number 3776814 from the 64 AIM. Thanks
        • 43238
        Re: Joe Lucia one more p/n please.
        Neil-----
        The GM #3776814 was, apparently, a PRODUCTION-only piece, never available in SERVICE. The 1964-era SERVICE part number for the grommet was GM #1194162. By 1967, this had become GM #381957 for BOTH PRODUCTION and SERVICE.
        The current part number for the grommet is the same as the part number for the shock grommet I provided earlier----GM #6270752. While the uninstalled bushing may be configured a bit differently than the original, the installed bushing will appear and perform the same.
