Front trailing arm bolt - NCRS Discussion Boards
  • Tom Sarno
    I have the front bolt on my trailing arms installed with the nut and cotter pin outboard. Is this correct?
    Tom
    • 43221
    Re: Front trailing arm bolt
    Tom-----
    Yes, that's the correct configuration.
    • William V.
      • December 1, 1988
      • 399
      Yes. With the body on the frame, you cannot get the bolt installed or removed unless the nut and pin are on the outboard side.
      Good Luck
        Yes *NM*
