C1-Wiper Transmission Removal - NCRS Discussion Boards
  • Dennis A.
    • April 30, 1999
    • 1010
    To install or remove the wiper transmissions, does the alum. dash insert have to be removed and on the driver side how does one get around the clutch/brake support without disconnecting everything? What is the best way to install and remove the wiper transmissions?
  • Ed Jennings
    Re: C1-Wiper Transmission Removal
    I have been able to get the lh trans out without removing the defroster duct, but it's a job I've done several times. It's probably easier to remove the duct, at least on your first attempt.
    • David Lyon
      I was lucky. My car was stripped of the instrument panel, defroster ducts, hoses, radio, cowl vent lever, etc. The only problem I had was getting a wrench on the driver's side left nut to remove that transmission. My transmissions were frozen, and I was told I would never get the cables to stretched long enough to reconnect to the wiper mount plate pulleys. So I had them re-done, and while I was at it had the plate refinished and the bearings replaced. It's better to do it all at once when you have it apart than have to go through it again. Good luck!
      • Richard E.
        • November 1, 1976
        • 200
        Dennis - Don't believe you need to remove the aluminum dash insert for the RH side. I did remove the package tray and the heater cover to gain some space.
        The drivers transmission is not so easy. I removed the steering wheel and driver's seat to get some mobility. A lot of patience, lots of new words, and several disconects in the under dash wiring. Just have to reach up, over, and around the brake pedal assy. The wiper cable hookup is also challenging. Good luck...Dick
        • Gary Bishop
          I had an article published in the Restorer a few years ago outlining the whole procedure including which wrenches and tips.
          • Dennis A.
            • April 30, 1999
            • 1010
            Re: C1-Wiper Transmission Removal Article
            Gary...
            How do I go ablout getting a copy of your article in the Restorer?
