68 Radiator Seals - NCRS Discussion Boards
68 Radiator Seals
  • Kurt B.
    • July 31, 1996
    • 971
    68 Radiator Seals
    Getting ready after many years to install radiator into my 68 Coupe small block with A/C.
    I believe there are some seals that go between the A/C condenser and the radiator.
    Where is the best place to find the exact positioning of these seals.
    Also, should the seals be installed to the radiator before the radiator gets installed in vehicle or should the seals be installed to the car and then the radiator installed ?
    Lastly, should the shrouds go in first and the radiator last. I seem to recall there are clearance issues. Fan and pulleys have not been installed to engine yet but water pump has been installed.
    It's been years since I disassembled the car and memory is not as good as it was once. (I should have taken better notes at disassembly)
    Thank you for an y and all help,
    Kurt Bunting # 26406
  • george romano
    Re: 68 Radiator Seals
    The absolute best place to buy these seals is Doc Rebuild. They are made exactly like the originals. His kits come with installation instructions showing the exact placement of each seal. None finer.
    203-366-1332
    George
    • Kurt B.
      • July 31, 1996
      • 971
      George,
      I purchased mine from Dr. Rebuild. From what you are telling me, as soon as I can find them, there will be directions for use included. Great, because the Assembly Manual wasn't much help.
      Thank you,
      Kurt
