Re;C1 Rear Axle Bearings - NCRS Discussion Boards
  • Terry D.
    • May 31, 1987
    • 2696
    Thanks for all the advice, if anyone has a problem with C1 axle bearings call Case's 55-57 Chevy Parts. 1-800-466-0041, talk to Scott or Steve. They have bearings for all solid axle cars.
  • John M.
    • January 1, 1999
    • 1553
    Re: Re;C1 Rear Axle Bearings
    Terry,
    Has anyone told you about the reconfiguration that needs to be done to the bearing seal to get long life out of them? The bearings that are available now are configured different than the origianls and will not give long life without the modification. If the car is going to be a seldom driven garage patato, then it is not really necessary, but if the car is going to have a lot of miles put on it then it is really necessary. Drop me an Email, and I can explain the
    process to you.
    Regards, John McGraw
