64 steering column - NCRS Discussion Boards
64 steering column
  • Joe Battocletti
    64 steering column
    Can a tilt or telescoping steering column be installed in a 64 without power steering? If so where might I find one?
  • Mike M.
    • May 31, 1974
    • 8396
    Re: 64 steering column
    NO PROBLEM INSTALLING A TELE COL IN YOUR 64. YOU CAN STEP UP TO THE PLATE AND FIGURE ON 1 TO 2 K FOR A VET COL THAT TELE'S ONLY(MID YEARS DIDN'T TILT) AND ASK FOR ON FOR A 65 TO 67 VET TELE COL. OR YOU CAN SCROUNGE THE JUNK YARDS FOR A CORVAIR THAT WAS OPTIONED WITH TELE. THEN ALL YOU HAVE TO DO IS USE THE MOUNTING BRACKETS OFF YOR 64 NON-TELE COL AND WELD THEM ON THE CORVAIR WHICH EXCEPT FOR THE BRACKETRY IS NEARLY IDENTICAL TO A MID YEAR TELE COL. HAVE ALSO SEEN C-3 TILT-TELE COLS INSTALLED IN MID YEARS BUT FIGURE IT WOULD REQUIRE A GOOD DEAL OF FABRICATION TO MOUNT THE C-3 COL IN YOUR C-2. GOOD LUCK, MIKE
    • Richard Hayes
      Hey Joe,
      Here's another alternative- a bit cheaper @ $500.
      Richard
