Leaking midyear coupe - NCRS Discussion Boards
  • Ed Jennings
    My 67 leaks somewhere up under the dash on the driver's side. The water lands on top of the air conditioning duct and ends up on my left leg prior to running off and saturating the carpet.
    On advice from Jerry Bramlett last year, I took the plennum vents off and sealed around the seams that I could reach. Whatever had been comming in on the right hand side pretty much stopped. I may have slowed it down on the left (I think), but there is still enough leak there as to render the car pretty much unuseable in wet weather.
    The car was purchased years back to be an everyday driver. Bought a coupe instead of a convertible for just that reason. I'm getting to the point of using it for a near daily driver again, but I gotta stop the leak first. Any suggestions as to where to look. Is it possible there is a blocked drain in the plennum? How would one access it?
    I kinda, sorta need to pull the dash completely out of the car to change one of the dash pads. Wonder if I'm going to have to do that before I'm quite ready in order to find the leak.
    • May 31, 1974
    • 8396
    Re: Leaking midyear coupe
    hate to be bearer of bad news but most leaks such as you describe will necessitate windshield removal. don't be suprised if you encounter some rust thru of the windshield frame. might get lucky and just find caulking dried up allowing h20 thru. good luck, mike
    • Ed Jennings
      I sealed around the windshield several years ago. Had no effect on the leak. If I can't find something else, I may have to get a windshield pro to pull the ws all the way out and see what I can find. I want to eliminate all the other possibilities first.
      • Dave McDufford
        • Dan Tewell
          Ed,
          It has been my experience that "windsheild" leaks are not really the fault of the windsheild. I have found time and again that the leak is between the birdcage and the bonding strip that is rivited to it. The factory applied a sealer between the two. Over time, this sealer dries out and leaks. In my 27 years experience, I've not seen a birdcage rust on the midyears.
          • Mike McKown
            How do you fix a leak between the birdcage and the bonding strip? Does it leak through the rivets?
              • May 31, 1974
              • 8396
              Dan: up here in the hills of western maryland, west virginia and western penna, where the winters are harsh and salt is cheap, rusty c-2 birdcages are common. i personally own two such coupes that required major windshield frame repairs. to give you an idea of the corrosive nature of our winter highways, i have a two owner 56 vet that the father and son put only 100k miles on it before i acquired her. one can place ones open hand thru the rust holes in the 56's frame. it lived nearly its entire life in preston county, w.va.. mike
              • Dan Tewell
                Mike, The way I repair them is to pull the windsheild along with the seal. I then take a die grinder and remove as much of the sealer as I can along with a small amount of the bonding strip. This will also scratch the birdcage. I then fill this void with a non hardening sealer. I use a urethane used for installing the newer windsheilds. Be sure to not get carried away and remove any of the finished top fiberglass, or your mouldings will not conceal your handy work.
                No it's not the rivits that leak.
                • Dan Tewell
                  Mike, Here in Ohio, salt is used like it's free. The 65 that I'm finishing up had extensive water damage to the interior. The seats were rusted in place. It took me 3 hours to remove the seats. When I pulled the windsheild, there was absoultly no rust on the birdcage what so ever. Looked like it did in 65. However, the sealer was cracked and open the whole way around where the birdcage meets the bonding strip (from door to door). This was the main water leak.
                  • Mike McKown
                    Is the caulking you are talking about what is pumped in at the base of the windshield as described in the service manual?
                    • Ed Jennings
                      Sounds like I need to pull the ws trim and have a looksee.
                      • Dan Tewell
                        Mike, I don't have a service manual, but I doubt it. The caulk I'm talking about was applied to the birdcage just before the bonding strip was rivited. This bonding strip is what the surround panel is bonded to at the base of the windsheild. I've never seen a midyear windsheild that leaked. It was always this joint that leaked.
                        • Floyd Dossey
                          Ed,
                          There is a metal tray which is part of the bird cage that the windshield and gasket sits in and it probably has rusted thru on the drivers side. Unless you pull the windshield and gasket no amount of sealer will stop the leak.
                          Floyd
                          65 Fuelie
                          • Michael H.
                            • July 31, 1998
                            • 180
                            I've seen a lot of water leaks come from the top of the door jamb and through the gap between the vent window and windshield post. They hide behind the dash liner until they reach an opening - it can appear to be coming from under the dash but it really isn't. The best way to trace the source is to use a leak detector solution and ultraviolet light. Pull the instrumnent panel and have someone slowly pour water/dye while you watch with the ultraviolet light.
