rear end ratio - NCRS Discussion Boards
rear end ratio
  • Ray G.
    • June 30, 1986
    • 136
    rear end ratio
    I have a 65 convertable small block, running 215/70 radials which I believe are close in size to the original. The rear end says "AM" which would be 3:36 gears
    but the tach reads 2500 rpm at 60 mph, and about 3000 rpm at 65 mph. Sounds like 3:08's to me? Any thoughts? Thanks, Ray
  • Craig S.
    • June 30, 1997
    • 2471
    Re: rear end ratio
    Ray - 2500rpm on my 3.55's is about 57-58mph on my 67 with GR70-15 radials, so I think you may be in the ballpark for your 3:36's. Doesn't sound like 3.08's to me....Craig
    • Dave McDufford
      Re: rear end ratio
      A program I downloaded from gearzone says with those tires 3.08 should be about 2300 at 60mph. Per the program the 3.36 would be 2521 rpm at 60mph.
      Dave
      • Craig S.
        • June 30, 1997
        • 2471
        Re: rear end ratio
        Sounds like a good program, I guess my guessing per my car was close!...Craig
          • 15674
          Re: rear end ratio
          Revs at 60 = axle ratio times OEM tire revs per mile.
          The revs per mile for 215/70R-15 and the OEM 7.75-15s are identical - 775, however, installed tire revs per mile do NOT affect the rev/speed relationship - only the accuracy of the speedometer.
          775 x 3.36 = 2604
          • Ray G.
            • June 30, 1986
            • 136
            Re: rear end ratio
            Thanks to all of you! I guess they are 3:36's after all!
            Ray
