Hello, Why do the half shafts u-joints only have grease fittings on the outside u-joint (nearest to the wheel) and the inside (nearest to the differential) do not? 72 454/400
72 half shaft u-joint grease fittings.
Re: 72 half shaft u-joint grease fittings.
Eric If the grease fittings are installed on the half shafts you may not be able to grease them as I have found it very hard to do without removing the shaft. No room to get at the grease fitting and as I remember the inside is hardest to get at..Your inside joints may be original. LyleLyle
- Top
