mid year speedo issue - NCRS Discussion Boards
  • Tony DiGiorgio
    Hello all, I have a strange problem hopoing someone can help me with. When I accelerate in my 67, the speedometer does not move accordingly until I push in on the clutch to make a shift. So I start out in first accelerate to appx 35, speedo stays at say 10mph and then when i push in clutch to shift to second, only then does needle move up to more accurate measure of speed. Anyone experience simiar kinda thing?
    Tahnks in advance,
    Tony Digiorgio
  • Mike M.
    • May 31, 1974
    • 8391
    Re: mid year speedo issue
    tony: i'd first check for an interference problem between the clutch linkage and the speedometer cable. normally they don't come innto close proximity, but ya never know what a previousowner/mechanic did under the dash or down by the transmission rods. good luck, mike
    • Wayne W.
      • April 30, 1982
      • 3605
      I have seen either end of the cable come out of the socket under acceleration. You should check both the drive end and at the speedo head.
      • Mike M.
        • May 31, 1974
        • 8391
        Wayne: regarding the cable that withdrew from the socket: was it a made-up cable that was a tad too short or were the corners rounded off the cable ends or distorted socket in the speedo head? thanks, mike
        • Wayne W.
          • April 30, 1982
          • 3605
          Some of both actually. I have seen it happen with a damaged cable and also with a replacement cable that was just a little short.
