Old Carpet Glue Removal Without Brain Damage - NCRS Discussion Boards
  • Jace H.
    • April 1, 1997
    • 253
    I need to remove the old excess carpet glue in my 67 roadster interior. What is the best product/process to use that will save the most of my diminished brain cells? I need to keep as many as possible now.
    Jace Holt
  • Ed Jennings
    Re: Old Carpet Glue Removal Without Brain Damage
    I have used a cup style wire brush on an electric drill sucessfully.
      • 11622
      I usually leave it. It gives the next layer of adhesive something to stick to, as it is more likely to adhere to old glue than to bare, clean fiberglass.
      Just my thoughts.
      Patrick
      • Mike M.
        • May 31, 1974
        • 8377
        ok to retain glue but i'd definitly remove any patches of rug material/jute etc that wouldn't bond to new rugs. wire brush or putty knife off old carpet debris. mike
        • Mike McKown
          Kinda' what I was thinking Patrick, if it's STUCK, LEAVE IT!
          Mike
          • Tracy C.
            • July 31, 2003
            • 2739
            YoU sAy "bBraIN dAMAgE" liKe iT"s a bAD ThiNG!!
            Never tried it, but good ole chemical paint stripper may do the trick.
            Definitly would be careful with a mechanical removal tool or roto brush. Lotsa curves in a floor and would be easy to hog right through the fiberglass if you aren't watching all points of contact.
            lotsa luck,
            tc
            • Jace H.
              • April 1, 1997
              • 253
              Thanks Dude! I WIll Need My Dead Head Music
              Thanks to all for the advise. "Wow this could really be far out" chemical fumes and Jerry Garcia!!!
              Jace
