68 - 69 427 tri-power component availability - NCRS Discussion Boards
  • Steve Antonucci
    Hello,
    I'm working on a 69 427-400hp tri-power engine restoration.
    Currently, I am trying to source all of the components needed
    to hook-up the carburetors. eg. fuel lines, throttle linkage,
    throttle cable brackets, vacuum lines, clips, brackets,etc....
    As this is a restoration, I want to use correct components. I
    have looked in Paragon's catalog. Also the ever popular ebay!
    Is Paragon's tri-power stuff good enough to pass judging, or
    should I look for original stuff and restore each piece as I go?
    Lastly, are there any differences between the 67, 68 & 69 tri-power
    air cleaner assemblies? I have my eye on a 67 air cleaner assembly,
    but I don't know if it is correct for a 69 application. Any and all
    input would be greatly appreciated.
    Steve
  • Dave M.
    • March 1, 1992
    • 36
    Re: 68 - 69 427 tri-power component availability
    Paragon's parts manual details whether the parts are restored originals, exact replicas, or if the parts will not pass NCRS scrutiny.
    • Craig S.
      • June 30, 1997
      • 2471
      Steve - I believe the air cleaner assembly was the same for all 3 years. Keep in mind there was the A.I.R. Smog version base too, for 67, this was a rare bird, but, with the air pump inclusion on the later years, maybe this part was used in 50 states emissions setups. Someone else will chime in on this point...Craig
