63 dash lights - NCRS Discussion Boards
63 dash lights
  • Chris Robertson # 37813
    63 dash lights
    Recently had my instrument cluster restored upon reinstallation my dash lights worked then upon turning the switch on and off a few times there were no dash lights the roller mechanism in the switch feel funny, and I have no power at the panel lights fuse, do I need a new head light switch? thanks
  • Ed Jennings
    Re: 63 dash lights
    If the switch "feels funny", there is a good chance that you need a new one. They are easy to R&I, so you may want to take it out and clean it throughly first. HL switches are relatively inexpensive and readily available. If there is something loose inside, (like one of the contacts), I'd pitch it.
      Re: 63 dash lights
      '63 was unique as the only year Corvette to use an '095 HL switch. If yours is a real McCoy original (the stamped steel, plated, side cover will bear an '095' emboss), you might think hard about restoring it vs. replacing it as it's a relatively unique part. Originals had a dimmer stage potentiameter with a rather large, finned, heat sink to thwart burn out that is very different in geometry from later service replacement switches.
      The 'numbers' on HL switch cover along with specifics of the bakelite body (brown vs. black, Etc.) are closely looked at in C1 judging because access with a flashlight and inspector's mirror is easier than C2/C3 cars. Still, you can usually 'save' a correct/original HL switch by taking it apart, cleaning it up, and bending the wiper arm of the potentiameter to regain solid/fresh contact with the resistor windings....
