68 327/350 Radiator Cap - NCRS Discussion Boards
  • Richard D.
    • December 1, 2002
    • 328
    Would a 16 lb. cap be OK to use in place of the 15lb. stock cap?
    My car came with a 16lb. cap, but it seems the spring has gone weak and it leaks out coolant from the vent tube.
    I fill the expansion/fill tank 1/2 way as recommended.
    What would be the consequences of running 1 lb. higher on the cap if I did?
    Thanks in advance for any advice,
    Rich
  • Robert C.
    • December 1, 1993
    • 1153
    Re: 68 327/350 Radiator Cap
    Not much difference. The pressure held inside by the cap ups the boiling point of the coolent. I would have your cap tested to see what the pressure really is.
    • Richard D.
      • December 1, 2002
      • 328
      Thanks Bob, I will do that.
      Rich
