Body drop shimming - NCRS Discussion Boards
Body drop shimming
  • Chuck R.
    • April 30, 1999
    • 1434
    Body drop shimming
    When dropping a different body onto the frame for the first time, is there a trick of the trade so to speak in getting it shimmed and squared up with a minimum of on again/off again jigging around?
    Again, just trying to plan ahead on what I'm going to need to get it done with a minimum on effort and cost.
    Thank again,
    Chuck
  • Mike M.
    • May 31, 1974
    • 8385
    Re: Body drop shimming
    chuck: there isn't any formulae for arriving at the # of shims needed when installing a body on a different frame or vice-versa. I'd insert about 3 shims at every body mount site, drop body gingerly, then observe the fit of the doors to the body jambs. It will be a trial and error experience but the bottom line is getting the gaps between doors and fenders consistent and you do this by adding or subtracting shims.Good luck, mike
    • Chuck R.
      • April 30, 1999
      • 1434
      Re: Thanks Mike
      That's what I figured, but wanted to hear it from another angle.
      Thanks again,
      Chuck
      • Chuck R.
        • April 30, 1999
        • 1434
        Re: Body drop part two for Mike
        What if the nose has been removed?
        Does the nose have to be re-attached to the body to get true door/fender gaps?
        How does that work?
        I planned on dropping the body and THEN re-attaching the nose being using the core support for a starting reference point.
        Thanks again for you help,
        Chuck
          • 15601
          Mike, and a lot of others, are in Nashville *TL*
          I'll try to hook Mike up with the laptop, but we may be too busy to get near a land line. I haven't gone wireless yet. A lot of folks will be off line this weekend. HAPPY BIRTHDAY.
          • Tracy C.
            • July 31, 2003
            • 2739
            I replaced the frame and front clip on my 63 using the method you descibed. I didn't use any shims to start with and "dry fit" the front end. I just backed away 15 - 20 feet and "eyeballed" the body line from the front to back of the entire car. Adding shims where required. You'll want to look from several view perspectives.
            Also find a GOOD example of a complete car and burn a roll of film taking Quality photos from various angles as a reference for the correct alignment.
            Good luck,
            tc
