Water Pump Pulley Spacer - NCRS Discussion Boards
  • Jim Damasiwicz
    Did 66 big block cars have the spacer installed on the water pump pulley?
  • Henry J.
    • November 1, 1999
    • 457
    Re: Water Pump Pulley Spacer
    I have compiled what I believe to be a complete list from the AIM of all the pulleys and associated spacers used on 66's. As far as I can see, no water pump pulley spacers are called out in the AIM for 66 big block cars. However, a lot of detail on the subject of pulleys appears to be missing in the AIM, so someone else may have better information to offer.
    • Mike M.
      • May 31, 1974
      • 8385
      never encountered any pully spacers. If the v-belts are in alignment, shouldn't need spacers but thats not to say a previous owner didn't see the need for a spacer if the flange pressed onto the h2o pump was misfitted. good luck, mike
      • Art A.
        • June 30, 1984
        • 834
        Don't use spacers------Use a wheel puller to pull the pulley attachment flange forward until the pully lines up with the other pullies.
        Art
        • Clem Z.
          • January 1, 2006
          • 9427
          are you sure you are not refering to a pulley reinforcement plate that is used on some waterpump pulleys to prevent the pulleys from cracking where they bend around the pump hub.
          • Jim Damasiwicz
            Yes, that what I'm referring too. Did the big block cars have this reinforcement spacer installed?
            • Clem Z.
              • January 1, 2006
              • 9427
              i am not sure all do but i know that some did.
              • Randy Swartout
                Funny thing, I saw this yesterday in the current Paragon catalog (pg 94) lists part # 846 as "66 327/300HP spacer/reinforcent. Attached is paragons reply to my inquiry
                "this part acts in two ways, one as a spacer to position the fan shroud in place and two as reinforcement to prevent center section of pulley from fracturing. Thank you for the inquiry, and have a good day.
                Sales Dept."
                Is this a repro of original part? Couldn't find in the AIM.
