C2 Front Suspension Torque Spec - NCRS Discussion Boards
  • George C.
    • November 1, 2001
    • 568
    I am putting the front suspension back together after a total rebuild and can not find the torque spec for the top bolt which holds the backing plate and the caliper bracket to the front spindle. AIM has nothing as this was installed as a sub assembly, and the 63 service manual refers to the brake anchor pin, drum brakes. The 65 manual has no additional information, Can someone tell me the right torque?
    Thanks as always,
    George
    #36809
    Re: C2 Front Suspension Torque Spec
    George -
    75 lb-ft. per the '67 Service Manual.
    • George C.
      • November 1, 2001
      • 568
      Jack,
      Thanks for the response. All I could find was reffering to the Brake Anchor Pin, and I wasn't sure if it should be something different.
