C-2 fuel tank - NCRS Discussion Boards
C-2 fuel tank
  • Rainer S.
    • May 31, 2003
    • 468
    C-2 fuel tank
    I am restoring a 63 SWC. The car has a new fuel tank, GM replacement, based on the stickers I found on the tank. Made from galvanized steel, with all the correct indentations. But it does not have the "Anderson" logo stamped next to the bottom sending unit, as the originals had.It was made in USA. Will I loose judging points,since it does not have the logo or should I replace the tank with a reproduction unit ,with the logo ?
    • 15672
    Re: C-2 fuel tank
    The area around the sending unit cannot be seen during flight judging due to the spare tire housing blocking the view, but the sides can be seen and I recall the JG says there is a detectable geometry difference between the original and later GM replacements, so that will cost a few points.
