C2: Testing a fan clutch? - NCRS Discussion Boards
  • Mark F.
    • March 1, 2002
    • 174
    While my radiator is in the shop for an overhaul, I'd thought I'd test my fan clutch. I mounted it on another Chevy and drove around until the temp got to 200 degrees on the S-W gauge. The fan spun as freely as it did when it was stone cold.
    Can I assume that my "test" indicates the fan clutch is junk?
    Thanks for your advice.
    Mark
  • William C.
    • May 31, 1975
    • 6037
    Re: C2: Testing a fan clutch?
    Pretty good assumption, not exactly "junk" but "in need of a rebuild" if it's an original.
    Bill Clupper #618
    • Mark F.
      • March 1, 2002
      • 174
      THANKS BILL. *NM*
      • Robert B.
        • March 1, 1992
        • 265
        Best way to test your fan clutch is to bring the car up to temp and once you turn the car off the fan should not spin more that a couple of turns. Good Luck
        • Mark F.
          • March 1, 2002
          • 174
          Thanks Bob. Spins freely. Junk. *NM*
