1963 Carter #3461S carburetor - NCRS Discussion Boards
  • Timothy B.
    • April 30, 1983
    • 5186
    Is there anyone that can indentify parts from my 3461 S carter carburetor as being correct. Primary ventury #'s 793-794, secendary ventury #'s 620-621, metering rods 16-389, and jets #'s 120-161 (primary) and 120-222 (secondary).
    Thanks for your help, Tim
    • 15678
    Re: 1963 Carter #3461S carburetor
    The secondary venturi clusters match mine, but my primary clusters are 633 and 634. Orignal owner, original carb. FWIW.
    These are the size and part numbers for the 3461S jets and rods.
    Primary main jet: .104" 120-404
    Metering rod: .060"/069" 16-389
    Secondary jet: .0689" 120-228
    I have no listing for a 120-161 jet. Double check that you read and listed the correct number. The 120-222 jet is .070".
