T-10 seals - NCRS Discussion Boards
T-10 seals
  • Mike Przano
    T-10 seals
    Can anyone recommend a supplier for a seal kit. Most I've checked with want to sell me the entire rebuild kit and all I have is a front seal leak. Thanks in advance.
    Mike
  • Karl #35089
    Re: T-10 seals
    For just a seal, try your local auto parts store... Other than that, I can recommend Larry Fischer at D&L Transmission for any T-10 parts (or muncie for that matter). See website below:
    -Karl
    D and L Transmission dot com
      Re: T-10 seals
      Mike -
      There is no front seal on a T-10 (or a Muncie); just the gasket between the bearing retainer and the main case. The only "seals" are O-rings on the shifter shafts in the side cover, the O-ring on the speedo gear sleeve, and the output shaft seal for the yoke.
      • Mike M.
        • May 31, 1974
        • 8385
        Re: T-10 seals
        if you're referring to the early t-10s(57 to 63) and not the super t-10s (which i'm totally unfamiliar with), then i don't think you will find ANY seals in the front of the tranny. the only true seal is pressed into the tailhousing and a leak there shows up there. if you have a leak up front, it could be the throw-out bearing retainer gasket , but most commonly the front leak is due to leakage betweem the cluster gear shaft and the t-10 case,which isn't an easy fix. if all you need is the retainer gasket, chevy ought to have one.if you're not in a hurry, send me your address and i'll send you one on the house. mike
        • Mike Przano
          Re: T-10 seals
          Thanks everyone for your response. If in fact it is the front gasket it sounds a little easier to replace than a seal. Haven't pulled the tranny yet so hopefully that's all it is.
          thanks again!
          Mike
          • Karl #35089
            Re: T-10 seals
            Hi John: Next time I should read closer... skipped right over that little "front" word in the original post. You are of course correct. -k
            • Mike Przano
              Re: T-10 seals
              Mike, unable to send you my address through the discussion board for some unknown reason. Please send me an email and I will reply with my address.
              Thanks!
