C2-56 coil location - NCRS Discussion Boards
C2-56 coil location
  • Joe Pennington
    C2-56 coil location
    On a 56 with the single carburetor and vacuum advance dist. Is the coil mounted on the right hand ignition shield bracket or is it mounted on the intake manifold (drivers side)? Thanks for your help. Joe
  • Mike M.
    • May 31, 1974
    • 8388
    Re: C2-56 coil location
    believe you need the figure 8 bracket that is available as repro. the bracket clamps to the distributor and the coil slips down in the smaller opening in the figure 8.mike
    • Joe Pennington
      Mike, thanks for the info on the figure "8" coil holder. I had seen the listing in the catalogs but didn't understand the application.
