C1 - 1960 Brake Problem - NCRS Discussion Boards
  • John Olcott
    I have been noticing some fading in the brakes and increased travel of the brake pedal. I do not see any leaking at the wheels or the master cylinder. I have set up an appointment with a mechanic. From my description he thought that either the brakes needed to be adjusted or the master cylinder would need replacing. I am attempting to keep the car original. If the master cylinder needs to be replaced what would your recommedation be? Have the present one rebuilt,try to find one somewhere or buy new (if possible)? Thanks for your help.
  • Donald L.
    • September 30, 1998
    • 461
    Re: C1 - 1960 Brake Problem
    Assuming you have the correct M/C (5454480-320-G), I would have it rebuilt and sleeved. There are numerous companies that do this and it usually only takes
    about 1 week turnaround.If you wantyo buy an original most major venders have them for
    about $300 rebuilt, sleeved and ready to install. Non original replacements are about $80.
    • Ed Jennings
      A rebuild kit is about $15 at any auto parts store. If the bore is not pitted in the area that the seal slides, a good honing and a rebuild kit should take care of it. From what you describe, your brakes probably need adjustment.
        C1 drum brakes are not self-adjusting like '63-'64, and require occasional adjustment as the linings wear; before putting money into the master cylinder, adjust the brakes (procedure is in the ST-12) and you'll probably be in good shape. My '57 only needed one adjustment in 5,000 miles after I restored it.
        • John Olcott
          Thanks for the help!! *NM* *NM*
