C1,Soft top frame - NCRS Discussion Boards
C1,Soft top frame
  • James Madison
    C1,Soft top frame
    Can you just change the rear bow on a 61-62 soft top frame to fit a 59 .. Or is it all togather different?
  • Dennis C.
    NCRS Past Judging Chairman
    • January 1, 1984
    • 2409
    Re: C1,Soft top frame
    It is, as you say, altogether different. 1961/62 have the "wind-split", those prior, do not.
    • Wayne P.
      • August 31, 1975
      • 1025
      I believe changing the bow will make the top work for your application.
      • Christopher R.
        • March 31, 1975
        • 1599
        The 61-62 rear bows are different from the 56-60s. Only difference, though, is the 61-62s have the indentation for the split. They are identical otherwise. They will swap out. That is, you can swap one for the other on the frame simply by unbolting them.
        • Mike E.
          • February 28, 1975
          • 5138
          There are subtle differences between the erly/mid/and late 56-60 tops. If you're not preparing a Duntov car, just change the rear bow and you have what you need.
          • James Madison
            Thanks all ,as always you guys make this hobbie a joy .. Keep it up, God bless all.......... James Madison.........
            • Bob Simard
              It's good to see
              ex-presidents involved with this hobby. I know I've sent lots of ex-presidents into this hobby.
