C1PILOT BEARING - NCRS Discussion Boards
C1PILOT BEARING
  • Joe D.
    • April 30, 2002
    • 382
    C1PILOT BEARING
    I am installing a pilot bearing on my 61. I bought a GM #10125896. I thought it would be a roller type bearing. It is a solid brass bearing with six grooves in it. Should I get a pilot bearing with needle bearings? Thanks, Joe DeLuca Member #37862
  • Steve Junkersfeld
    Re: C1PILOT BEARING
    Joe, My experience with my 56, and with numerous other vehicles, is that a new pilot bushing (probably bronze vice brass) works just as good as a pilot bearing. Make sure it slides easily onto the transmission pilot shaft before installing it into the rear of the crankshaft and put a light coat of grease on the tip of the pilot shaft prior to re-installing the transmission. Steve
    • Mike M.
      • May 31, 1974
      • 8389
      Re: C1PILOT BEARING
      your 61 originally had the bronze bushing. roller bearing preferrable if you're gonna put 100k mile/year on it. either bearing or bushing will work for infrequent trips about town or onto trailer. mike
      • Tom P.
        • April 1, 1980
        • 1815
        Re: C1PILOT BEARING
        If you use roller pilot bearing------------THOROUGHLY pack it with grease. Otherwise they are prone to dry out in a short time and disentegrate.
          • 43222
          Re: C1PILOT BEARING
          Joe----
          I agree with the others; the bronze bushing will work just fine. They've served well for literally millions of miles on millions of cars. However, if you want the roller bearing it's GM #14061685.
          • Lonnie Johnson
            Re: C1PILOT BEARING
            As and add-on to what Steve said, after you press it into the back end of the crankshaft, make sure the transmission pilot shaft still turns free in the bearing. Sometimes if the fit is too close, the bearing will close down a bit on installation and cause a "too-tight" fit. That doesn't work well, (voice of experience!)
