C1 upper windshield molding - NCRS Discussion Boards
  • Ed Jennings
    I have a C1 upper windshield molding with a couple pf screw holes that shouldn't be there. Is there anyone out there that repairs these kind of problems? I can weld the holes up myself, but it will look like I did it if I do! Obviously a job for a pro.
  • Mark Malone
    Re: C1 upper windshield molding
    Ed,
    be carefull with this one as I had a small holed welded up on a fender moulding and although it polished out well it was a slightly different color.
    Mark.
    My Vette Page
    • Mike M.
      • May 31, 1974
      • 8391
      ed--you'll have to experiment with various stainless steel wire in your mig welder,grind, sand and buff in order to compare color of various welding wire/rods available.mike
      • Ed Jennings
        That's why I was sort of hoping to find someone who had already invented that particular wheel.
        • John M.
          • January 1, 1999
          • 1553
          Ed,
          I used some 304 stainless wire in my MIG welder and after grinding and polishing, the repair had a different color to it. After flash chroming the moulding however, it is undetectable. There used to be a guy in my Austin who did this type of work, and his repairs were perfect. He used a TIG welder and applied shielding gas to both sides of of the moulding and used a different alloy of stainless. After doing a couple of these repairs, I figured that my time was better spent doing something else! If I ever get myself a TIG unit, I may try this again, but could not get the precise heat control I needed with the MIG welder, and I had real metal distortion problems. I would guess that with the thickness of your windshield header, this distortion would not be a real issue.
          Regards, John McGraw
          • Ed Jennings
            Thanks, John. I found a guy in NY who does this sort of thing and I think this is one I'd be better off sending out. I try to do almost everything myself, but I guess you can't be an expert at all of it.
