Master Cylinder Part Nunber - NCRS Discussion Boards
  • Jerry C.
    • November 1, 1995
    • 741
    Anyone know what part number 5450233 is for.
    • 43221
    Re: Master Cylinder Part Nunber
    Jerry-----
    Is this an actual master cylinder PART NUMBER or is this a master cylinder CASTING NUMBER?
    • Jerry C.
      • November 1, 1995
      • 741
      Part # is 6450233 and only other # are 1" Dia and D3. This is a Delco unit and came on my 60 and looks just like the correct 022 cylinder
        • 43221
        Jerry-----
        What you are describing sounds like a master cylinder CASTING number. I don't have any info on this particular number. The unit that it is part of may be a later SERVICE replacement for the original master cylinder.
        • Bernard M.
          • August 31, 1994
          • 341
          Don't have my reference material in front of me, but a 233 casting number was, I believe, what was used prior to the 022 master cylinder. Latest use in a Corvette was 1956. I can check when I get home tonight. Is there a number stamped into the plug on the end of the master cylinder?
          • Jerry C.
            • November 1, 1995
            • 741
            Numbers on cap 5454350 320-H
            • Bernard M.
              • August 31, 1994
              • 341
              5450233 casting was used in a number of applications, including Corvettes prior to 1957. 5454350 is the part number. It's original application was 1954-1955 Buick without power brakes.
