C2 63 Seat Belt Reinforcement Corner - NCRS Discussion Boards
  • Harry Sadlock
    I need to replace my LH outer seat belt reinforcement corner. I took a brief look and it looks impossible to replace with the body on. Any guidance would be appreciated.
    Harry.
  • Gary Kemp
    Re: C2 63 Seat Belt Reinforcement Corner
    Harry, I just did this last week. The nut I got from Volunteer Products is slim (maybe 3/16" thick). I bent a thin 11/16 open end wrench and was able to install with a little patience. I used some weatherstrip adhesive to hold the nut to the wrench to get it started. The other belts all had the nut welded in place and therefore not a problems. I was going to get a cheap china made wrench and grind it down but found an old one laying around wanting to be used.
    Good luck!
    Gary
