68 small block spark plug shields - NCRS Discussion Boards
  • Kurt B.
    • July 31, 1996
    • 971
    Greetings,
    I should have thought of this sooner, BUT can the spark plug shields that mount in the recess of the small block exhaust manifolds to keep heat from the spark plugs, be installed with the motor in the car or does it have to come back out?
    Are these shields still available from GM or any aftermarket vendors?
    Lastly, how are they held in place?
    Thank you,
    Kurt Bunting #26406
  • George D.
    • August 31, 2000
    • 225
    Re: 68 small block spark plug shields
    They can be installed with the engine in the car. However, they can be a little trying to install. They are held in place with 1/4-20 half inch long hex head bolts. There should be tapped holes in the block for the bolts. If you have an AIM consult it it for a better idea. I don't know if they are still available from GM, but the inner heat shields are available from most repro vendors.
    • Christopher R.
      • March 31, 1975
      • 1599
      You can get at them with the engine in the car. Might be easier from underneath. I've done them from the top, but it's tricky. You can't see, and you're doing it by feel. Underneath is much easier. Little 1/4 bolts. I believe the ones with the integral lock washers. Same ones that hold the timing cover and clutch inspection plate on. The usual vendors sell the shields and the bolts. They're cheap. Chevy might also still carry the shiels, but you won't save much there because of their low price.
      • Wayne P.
        • August 31, 1975
        • 1025
        GM still has one of the shields which works in two places. The other will have to come from repro. As I recall on the right rear, the starter will have to be removed or at least dropped down.
          • 43222
          Kurt----
          As others have described, you can install the shields with the engine in the car and the manifolds installed, but it's a little tedious. VERY do-able, though.
          As far as availability of the shields, I've got good news and bad news for you. First, the good news. Both shields are still available from GM. Here are the part numbers:
          left rear and right front-----GM #3817657
          right rear and left front-----GM #3917664
          Now the bad news: the GM #3817657 currently GM lists for $57.89/each. The GM #3917664 is much less expensive, though, at only $10.96 each.
          I think that you could get these for less in reproduction.
          • Kurt B.
            • July 31, 1996
            • 971
            Thank you one and all, for the informative replies.
            Much appreciate it as always,
            Kurt Bunting
