1962 Gas Tank - NCRS Discussion Boards
1962 Gas Tank
  • Terry D.
    • May 31, 1987
    • 2691
    1962 Gas Tank
    Bought a new tank from Quanta Products, went in ok, not the easiest job I've every tackeled, but now the fiberglass cover won't fit. It's as if the tank is too tall. Straps are tight, everything works OK, no leaks, but no way the lid is going back on. What did I do wrong?
  • Christopher R.
    • March 31, 1975
    • 1599
    Re: 1962 Gas Tank
    If you got the old straps back on, the tank is not too tall.
    Where is the cover interfering?
    • Mike E.
      • February 28, 1975
      • 5136
      Re: 1962 Gas Tank
      Had the same problem on a car I was getting ready to sell. Supplier said "we've never had that kid of a problem before". Old tank went right in and cover went back on--new tank went back in, cover wouldn't go all the way down. Car was sold with cover not flush.
      Mike Ernst
      • john38706
        Re: 1962 Gas Tank
        you need to center the tank in the hole. if it is too far to one side it will hit the top cover. been there.
        • Terry D.
          • May 31, 1987
          • 2691
          Re: 1962 Gas Tank
          Ok, the tank is centered and the lid is hitting on the back of the tank. It appears that the tank could slid forward, but when I do that then the straps don't seem to reach. Why are there indentations in the tank if the straps don't fit in them? Thanks for all the help.
          • Dennis C.
            NCRS Past Judging Chairman
            • January 1, 1984
            • 2409
            Re: 1962 Gas Tank
            Always wondered that myself... Same on a 24 gallon tank car... Dennis
            • john38706
              Re: 1962 Gas Tank
              terry, i don't remember what brand of repro tank i used but i had no fit problems and i have used 3 of them. let me check for the maker.
              • Christopher R.
                • March 31, 1975
                • 1599
                Re: 1962 Gas Tank
                I refurbished the original tank on my '62 last year. The original straps came out of and went back into the grooves in the tank. I don't see how the straps could reach any other way. It's a stretch as it is to get them reconnected. The straps just barely make it with the shorter distance provided by the grooves. Don't see how you could ever get the straps connected unless they were in right.
                Sounds like we're talking about 2 different things. But maybe that's a solution to your problem.
