C2 Intake #3890490 Temp Sensor - NCRS Discussion Boards
  • Paul L.
    • November 1, 2002
    • 1414
    I picked up this #3890490 intake on EBay for a very decent price. It arrived today. I stripped off the old peripherals such as the heater hose nozzle, t-stat housing and re-tapped all threads. It is a solid, straight if still dirty unit. Cleaning will follow. My question is: Where might I obtain that temp sensor at the front of the manifold? You can see remnants of the old in the pic.
  • Bob R.
    • June 30, 2002
    • 1595
    Re: C2 Intake #3890490 Temp Sensor
    I think you can find one at Autozone for just a couple of bucks.
    • Paul L.
      • November 1, 2002
      • 1414
      I located one at a local parts store for $8.00. The manufacturer is Standard Motor Products Inc. of NJ. I have read the thread on C1 sensor calibration problems so will keep a close eye on the temp gauge.
        • 43242
        Paul-----
        The Standard Automotive Products temp sender TS-6 generally provides acceptable calibration.
        • Paul L.
          • November 1, 2002
          • 1414
          That's exactly the one the shop recommended and I bought. The parts books showed it to be GM #01513321 equivalent.
          • Paul L.
            • November 1, 2002
            • 1414
            Re: Pic of Temp Sensor
            I do not know how far off it is from a correct sensor but as suggested by Joe, it may be adequately functional and accurate. We shall see.
            • Paul L.
              • November 1, 2002
              • 1414
              Here is the finished product with a new heater spout and temp sensor. Lots of lacquer thinner scrubbing with steel wool and scraping with brushes and a razor blade but it does look good. That is VHT engine 550F cast aluminum paint.
                • 43242
                Paul-----
                Save for the embossed lettering, the unit looks pretty much identical to the GM #1513321.
                One thing that's interesting is that the sender comes with pre-applied sealant. However, note that the bottom few threads are left exposed. This is, essentially, what I have previously recommended regarding sender sealing. I prefer to seal the lower threads by applying sealer to the manifold lower threads with a q-tip. However, the application of sealer to just the upper portion of the threads on the sender should work equally as well.
