1966 headlight Electrical problem - NCRS Discussion Boards
  • Ronnie Robertson # 36786
    Just reinstalled the headlights in my '66 after extensive work. Lights work OK, both low and high beams, but on low beam the high beam lamps have a slight glow on the elements.
    Any ideas?
    Thanks, Ronnie
  • Mike M.
    • May 31, 1974
    • 8403
    Re: 1966 headlight Electrical problem
    get the wiring schematics and check your arrangement of wires going to the headlights. bet you've switched 2 of the three wires going to the high beams. mike
    • William C.
      • May 31, 1975
      • 6037
      Best bet is a grounding problem, recheck all grounds, remember the star washer goes between the wire terminal and the metal framework, not on the bolt head side. The purpose of the star washer is to break thru the paint to obtain a solid ground.
      Bill Clupper #618
