67 cpe window channel liner - NCRS Discussion Boards
  • Thomas C.
    • August 31, 2000
    • 133
    Does anyone know of a source for the window channel (rear ,lower, inside door) liner for a 67 coupe? I bought what I thought was correct from Dr. Rebuild but it is only a felt fabric. The original liner has metal/rubber/felt and snaps into the metal run inside the door. Any ideas on restoring my originals?
  • Mike M.
    • May 31, 1974
    • 8377
    Re: 67 cpe window channel liner
    tom; forget about restoring your originals. there was a guy in calif who advertised in driveline about 10 years ago who had near perfect repros. if no one posts his name or address in a day or two , will go to barn and get his address for you as i can't remember the details. seems they were about 70 per pair bach then but they worked and looked near perfect. mike
    • Geoff C.
      • May 31, 1979
      • 1613
      • Thomas C.
        • August 31, 2000
        • 133
        Re: Flex Channel v. Rear Channel Liner
        Thanks for clearing that up for me Doc. I guess I need to order the Flex channel. Tom
