C2 fuel gauge - NCRS Discussion Boards
C2 fuel gauge
  • Richard Love
    C2 fuel gauge
    Fuel gauge is stuck on 1/2 tank. I have power to both sides of the fuse. Anything else I can check prior to changing the sending unit.
  • Scott Butville
    Re: C2 fuel gauge
    Look in the archives. The sending unit can be checked by disconnecting the "S" and "I" leads and touching them together (pegs gauge one way) and then grounding the brown lead which pegs the gauge in the opposite direction. If the gauge doesn't move, it's not the sender. I recently had the terminal off the back of my fuel gauge and when I reconnected it, one of the wires inside the terminal pushed back and wasn't making contact leaving the gauge stuck on half.
      Re: C2 fuel gauge
      You'll find a nice troubleshooting chart for the unique fuel gauge system common to mid-year Corvette in your copy of the shop manual ('63-65) or chassis service manual ('66 and '67). Chart lists what to check based on gauge pointer symptom....
