soak hydraulic lifters? - NCRS Discussion Boards
  • Mark H.
    • July 31, 1998
    • 384
    Is this an old wives tale, or is it necessary to soak a set of new hydraulic lifters in oil overnight to "prime" them?
  • Mike M.
    • May 31, 1974
    • 8396
    Re: soak hydraulic lifters?
    probably an ole wives tale. just make sure you coat the lifters and cam with food quality cam and lifter lubricant before you fire the old girl up. mike
    • Mike Sasser
      Food Quality lube........is that corn or vegetable oil? :-)
      • Mike M.
        • May 31, 1974
        • 8396
        I usually buy about 10 avacodos(spelling a problem with me) put them in a big pot , stomp the feces out of em, then paint the resulting mess on the cam and lifters mike
        • George Romano
          I only use the good stuff....
          extra virgin olive oil!
          • Craig S.
            • June 30, 1997
            • 2471
            Re: I only use the good stuff....
            With Marinara post lube Pasta! Oppps, wrong board...
            • Clem Z.
              • January 1, 2006
              • 9427
              that is the only thing virgin in italy
              is the olive oil.
