C1 Engine/ Rear end ID - NCRS Discussion Boards
  • Bud Landacre
    Engine casting# (Driver's side rear top of block)3782870. Haven't removed the road draft tube to check the other side. Differential carrier (facing the rear of the car) R/H side 64-63?
    3725899 GM T
    8
    L/H side (machined pad) BB0314
    Bud Landacre
  • Mike M.
    • May 31, 1974
    • 8385
    Re: C1 Engine/ Rear end ID
    most C-1's did't use 870 blocks. they (870's) were used in 62 to 65 vets and pass cars.if your c-1 is a 62 then the 870 might be appropriate for a 62. what is pad data and casting date and vin of c-1?
      Bud -
      The diff carrier is from a late 1963 non-Posi passenger car.
