1960 Motor Mounts - NCRS Discussion Boards
1960 Motor Mounts
  • Bob Simard
    1960 Motor Mounts
    The motor on my 60 hits the fan shroud when turning with any speed (lateral g's). Is this due to a defective mount or do I need to reshape the shroud? The mounts are about 15 years old and do not seem very tight in the mounting bolts. Who makes a quality rubber mount? Thanks
  • Dennis C.
    NCRS Past Judging Chairman
    • January 1, 1984
    • 2409
    Re: 1960 Motor Mounts
    Bob, Along with checking the front motor mounts, might be worthwhile to confirm that the O.D. of your engine fan is correct. Is your car equipped with the standard 4 blade or optional clutch 5 blade? I would not start hammering on your shroud quite yet. Dennis
    • Bob Simard
      It is the five blade fan with clutch.
      • Dennis C.
        • January 1, 1984
        • 2409
        As best you can, measure max OD of the fan.
        • Bob Simard
          Fan O.D.
          I think I have found the problem. The fan blade is steel and the O. D. is 18 inches. No wonder it rubs on sharp turns. Thanks for the help, especially to Jack Humphrey.
          • Dennis C.
            • January 1, 1984
            • 2409
            Re: Fan O.D.
            Bob, Glad you discovered the problem. OEM fan is about 16 3/4" O.D. There is another fan out there which is identical in every way except it is 17 3/4". It sounds like that's the one you've got. If somehow you could remove 1/2" from the tip of each blade, you would have created the correct part and the rub would go away. Best, Dennis
            • Mike M.
              • May 31, 1974
              • 8377
              bob: don't remove fan tips with a chainsaw as the dipstick attempted. mike
              • Dennis C.
                • January 1, 1984
                • 2409
                I think the chain saw method would have worked better if I had removed the fan from the engine first. Dipstick
                • Dennis C.
                  • January 1, 1984
                  • 2409
                  ...After turning off the key...
