Another Cowl Vent ? - NCRS Discussion Boards
Another Cowl Vent ?
  • M W.
    • July 31, 2001
    • 835
    Another Cowl Vent ?
    Hi all,
    I am trying to locate a source for the adjusting bolts used on my 1961 cowl vent adjusting lever. The AIM shows the use of two, but one can be removed if it interfers with the radio tubes on the side. Any help would be appreciated.
    Craig Willetts
    NCRS # 36551
    1961 2x4 245 HP
    Vin# 4719
    Save your Money and buy a C-1
  • John M.
    • January 1, 1999
    • 1553
    Re: Another Cowl Vent ?
    Craig,
    Several of the vendors including Paragon carry the bolts. They are carriage head bolts of the same design as those that attach the link to the actuator.
    Regards, John McGraw
    • M W.
      • July 31, 2001
      • 835
      John,
      As far as the catalogs go, I have looked through them and just don't seem to find where it references a specific carriage bolt. If you can tell me which page of the Paragon catalog I would greatly appreciate it. Thanks.
      Craig W.
      • John M.
        • January 1, 1999
        • 1553
        Craig,
        I mis-spoke, the hardware is in Corvette Central's catalog and is is part # 481119. This gives you all the hardware for the entire vent assy, but if you just need a couple of bolts, you can probably find them at your local bolt supplier or hardware store.
        • Chuck L.
          • July 31, 1996
          • 260
          I just took one of my carriage bolts out of my 62 and easily matched it at an Ace Hardware. Chuck
          Chuck Lyman
          Kansas City Chapter
