Season Mechanic or Old Fart - NCRS Discussion Boards
  • roy braatz
    Ok I'm an old fart too,and I for-got why as you hold your hand cuped over the carb as the engine is runing ,the RPM picks up and the engine runs smoooother. HELP
  • John M.
    • January 1, 1999
    • 1553
    Re: Season Mechanic or Old Fart
    Roy,
    This would indicate a too lean an idle mixture. First place I would look is a bad vaccuum leak! Knowing your tastes tend to run toward Powerglide cars like me, Don't forget to check the vaccuum modulator for a leak.
    Regards, John McGraw
    • roy braatz
      John ! Now we do like powerglide vetts , just lazy I think. But I do have a 67 4 speed that I drive only on mornings before I get tired. It's my son-in-laws 69 vett. He put a rebuilt carb on pep-boys and it idels bad , but when I put my hand over it she runs nice.
      • Mike M.
        • May 31, 1974
        • 8389
        Roy: how old ya gotta be to be considered an ole cheese cutter?
        • roy braatz
          Mike just a little uglier then you , but I'm 63 and geting S.S. many of the original members of NCRS ARE old farts.
          • Christopher R.
            • March 31, 1975
            • 1599
            Your cupped hand is restricting air flow, making it run ricer, which is what it sounds like it wants. Therefore, without your hand, it is running too lean. Either it's adjusted too lean, or it's got a vacuum leak somewhere.
            • Christopher R.
              • March 31, 1975
              • 1599
              One More Thing
              If the carb backfires while your hand is there, you won't be happy. And it may want to backfire, seeing as how something's wrong with it, and you're fiddling with it.
