Engine ID# Help - NCRS Discussion Boards
Engine ID# Help
  • M W.
    • July 31, 2001
    • 835
    Engine ID# Help
    Csn someone please tell me what engine this is and what application it was used for please? GM # 3970010
    Craig Willetts
    • 43221
    Re: Engine ID# Help
    Craig-----
    GM casting number 3970010 is a block casting which was used over a number of years from late 1969 through 1980 for most Chevrolet 350 cid engines used in Corvettes, other Chevrolet cars and trucks. It was also used for late 1969 Camaro Z-28 302 cid engines, but, otherwise, it was used exclusively for 350 cid applications. It is a 4.00" bore block with the "large" main bearings used on most small blocks from 1968-onward. These blocks were manufactured in both 2 bolt and 4 bolt main configurations.
      Re: Engine ID# Help
      Craig -
      If you'll post all the numbers stamped on the machined pad on the block in front of the passenger side cylinder head and the casting date (opposite side of the bellhousing area from the 3970010 casting number), we can probably dope it out for you.
