'72 blinker - NCRS Discussion Boards
'72 blinker
  • Tony 38901
    '72 blinker
    My right turn dash turn signal doesn't blink. The left works fine. I checked the bulb and it's OK. I hear the blinker when I turn it on & the signals on the outside of the car work. Any ideas?
  • Bernard S.
    • June 30, 1992
    • 56
    Re: '72 blinker
    Tony: Try your hazard lights,if both left and right blink check ypur blinker flasher.
    Bernie
    • Tony 38901
      Re: '72 blinker
      Just tried the hazards, the right side dash blinker still doesn't work. Eveything else works as it should. Also noted that the hazards seem to have an "irregular heartbeat". The blinking is not consistent, nothing very unusual, don't know if thats normal.
      • Dave S.
        • August 31, 1992
        • 2925
        Re: '72 blinker
        The hazard flasher and directional flasher are independent. You have two different flashers. If the bulb is good and the flashers are working properly then there must be a wiring problem.
          • 15601
          Re: '72 blinker *TL*
          Tony,
          Check the front side marker light. In 1971 and newer the front side marker is tied into the turn signal circuit. If front parking, side marker and rear tail light all flash, but dash light is on steady on only one side and other side works OK it has to be wiring. I would begin with a wiring diagram and check that all the ground points on the lighting circuits, front and rear are clean and tight.
