C2: Powerglide fluid capacity & recommendation - NCRS Discussion Boards
  • Mark F.
    • March 1, 2002
    • 174
    The engine and the (original) Powerglide have been reinstalled in my '65. I've consulted two sources for the transmission fluid capacity, the Shop Manual '65 Supplement and the Owner's Guide. The S/M says the capacity is 3 pints, while the O/G says it is 9 quarts. Huh? Your advice is, as always, greatly appreciated.
    Mark
  • Wayne W.
    • April 30, 1982
    • 3605
    Re: C2: Powerglide fluid capacity & recommendation
    If the transmission is completely dry including the converter use the higher number. If you only drain the pan, it would be 3-4 quarts.
    • Mark F.
      • March 1, 2002
      • 174
      Thanks, Wayne. *NM*
      • Mark F.
        • March 1, 2002
        • 174
        Thanks, Wayne *NM*
