MID YEAR DIFFERENTIAL ID - NCRS Discussion Boards
  • Neil L.
    • February 1, 1997
    • 44
    ON A MID YEAR, WHERE EXACTLY IS THE TWO LETTER ID LOCATED ON THE DIFFERENTIAL? DO I NEED TO REMOVE ANY BRACKETS TO FIND IT?
    • 43221
    Re: MID YEAR DIFFERENTIAL ID
    Neil----
    It's on the bottom flat surface of the carrier housing, just forward of where the cover attaches. It's often a light stamping that may require wire brushing to see adequately.
    • Brian Monticello
      Here's what the markings look like (see pic). They face the ground. As Joe mentioned, I had to clean with a wire brush to see them.
      Brian
      • Wayne M.
        • March 1, 1980
        • 6414
        CA is a 3.36 ratio non-positraction for '63 and '64, as evidenced by the date following the code.
