C1 rear axle - NCRS Discussion Boards
C1 rear axle
  • Bud Landacre
    C1 rear axle
    I just noticed some fluid on the inside of the rear tire on my 62. I haven't pulled the drum yet but on the assumption it is either the brake cylinder or the axle seal can anyone tell me about the availability of parts for this area, seals, bearings, wheel cylinders etc.? How many are available through local parts suppliers and/or what is a good source for those that aren't?
    Bud Landacre
    #39699
  • roy braatz
    Re: C1 rear axle
    Your local parts house should be able to get them.
    • Terry D.
      • May 31, 1987
      • 2691
      Re: C1 rear axle
      Bud,
      If your local shop doesn't have them try Kanter Auto Products, 1-800-526-1096 or www.kanter.com. They have a free catalog.
      If you find that it is the axle seal, check that your vent is not plugged, this will cause leaking in that area.
