C1 Replacement Transmission Tunnel Panels - NCRS Discussion Boards
  • Ed T.
    • November 1, 2002
    • 95
    My 62 has a large rough cut hole in the transmission tunnel where someone probably removed the shifter from above. Now I am looking for a fiberglass replacement panel. I see tunnels for 53-55 models. Anyone know if these have the same contours as the 62? Any other suggestions would be appreciated...Ed
  • Karl #35089
    Re: C1 Replacement Transmission Tunnel Panels
    Ed: I believe the 61/62 tunnel is different from earlier, but they do make a HL patch panel for the 61-62. CC # 231004 and I'm sure others carry it as well.
    -Karl
    • Ed T.
      • November 1, 2002
      • 95
      Hi Karl,
      I had seen the CC tunnel for the 53-55, but the online catalog did not display the 61-62 tunnel. The part number you gave me did the trick. Thanks...Ed
      • Doug Flaten
        At least you are not as ignorant as I was 15 years ago. After joining NCRS, I called up then team leader Mike Ernst and asked him about the transmission / shifter access plate. My '61 had a tin panel covering up the hole, and I just knew it was missing a nice factory fiberglass piece. It pays to get the assembly manual and other manuals. Oh well, I bet Mike had a good chuckle over it after I got off the phone.
        • Ed T.
          • November 1, 2002
          • 95
          Sometimes ignorance is bliss, but there is so much information and friendly advise available online (like this great website) and elsewhere these days that its hard not to know something...Ed
