Cam bearing journals #1,2,3,4 all have oil holes at top and bottom, 180 degrees apart. #5 has 3 holes at the top spaced about 20? degrees apart. When I removed the bearings, I noticed that #2,3,4,5 all had 1 hole each. #1 had 2 holes about 110 degrees apart. When installing new bearings, I assume the holes in the bearings should be aligned with the holes in the journals. Since there is not a unique hole-to-hole position, what is the "right" way to place the bearings ?
Steve
Steve
