Vacuum advance tube on 71 350 270 auto - NCRS Discussion Boards
  • Ralph A.
    • May 31, 2002
    • 236
    The vacuum advnace line from the distributer to the carb. For 1971 350 270hp automatic. Was there a metal piece with a hose on either end or just a 1 piece rubber hose. This is a late model 71 (April)
    Ralph Adams
    NCRS: 38137 LA: 112
    Slidell, LA 70461
    1969 350/300 LeMans Blue Conv (restoring)
    1971 350/270 Bridgehampton Blue Conv (top flight)
    1972 350/200 War Bonnet Yellow Conv (restoring)
    2001 Bowling Green Metallic Conv (fun car)
    • 43221
    Re: Vacuum advance tube on 71 350 270 auto
    Ralph-----
    There was a steel line used for the vacuum advance tube which was connected on either end by rubber tubing.
      • 11643
      Ralph,
      In addition, the metal tube is not currently available in reproduction. There is a good diagram in Dr. Rebuild's catalog of the tube and the rubber fittings, but DESPITE showing that the tube is available, you will get another tube that you need to modify and/or bend to fit.
      You car isn't too late. Jack H's 71 is also from April, mine from mid June.
      Patrick
      • Ralph A.
        • May 31, 2002
        • 236
        Thanks Joe, received mix info from the parts suppliers that it was not on a 71.
        RA
        Ralph Adams
        NCRS: 38137 LA: 112
        Slidell, LA 70461
        • Ralph A.
          • May 31, 2002
          • 236
          Can you send photo of its shape and possible source. Dr. Rebuild - NO, Paragon - NO
          email ralphna@hotmail.com
          Ralph
          Ralph Adams
          NCRS: 38137 LA: 112
          Slidell, LA 70461
            • 11643
            Ralph,
            Like you, I don't have a correct one, either. Jack might. I likely have a picture of one, but that will take some digging.
            Patrick
            • Ralph A.
              • May 31, 2002
              • 236
              Specs
              Can you give me specs on the tube (dia, length etc) so I can try to fin one.
              Picture would be helpfull.
              Ralph
              Ralph Adams
              NCRS: 38137 LA: 112
              Slidell, LA 70461
                Thanks for ISP address; digital pix enroute.... *NM*
                • Ralph A.
                  • May 31, 2002
                  • 236
                  Thanks Jack subject closed *NM*
                  Ralph Adams
                  NCRS: 38137 LA: 112
                  Slidell, LA 70461
