C1 Gasket - NCRS Discussion Boards
C1 Gasket
  • Dennis C.
    NCRS Past Judging Chairman
    • January 1, 1984
    • 2409
    C1 Gasket
    Am in the market for source & P/N of the gasket that seals the road draft tube or PCV hose adaptor. This, of course, assumes they used one. Thanks.
  • roy braatz
    Re: C1 Gasket
    It came in a engine gasket kit, The old ones. Now???? but it's easy to make.
    • Loren L.
      • April 30, 1976
      • 4104
      Re: C1 Gasket
      1962 AIM, section 6, sheet 11, does NOT show one. June 1, 1961 Pts Bk in Gr 1.762 does NOT list one, but I'm sure the vendors will sell you one...
      • William C.
        • May 31, 1975
        • 6037
        Re: C1 Gasket
        In theory, the baffled unit should prevent liquid from getting to the exit for the road draft tube.
        Bill Clupper #618
        • Dennis C.
          • January 1, 1984
          • 2409
          Re: C1 Gasket
          Thanks guys... Guess that's one less thing in life I have to worry about.
          • Mike M.
            • May 31, 1974
            • 8385
            Re: C1 Gasket
            as roy pointed out , the paper compsition gasket comes in the overhaul gasket set.Even tho c-1 probably didn't use them , i install them ( Waste not want not). As i type this , the FBI are pulling in the driveway with a one-way ticket to sing sing.And all i did was makeup a set of plug wires.
            • Dave Christensen
              Re: C1 Gasket
              I have a cork gasket on my 56 draft tube. I think that I got it from Mary Jo.
              After 4,000 miles, it does leak.
              Dave Christensen
              • John M.
                • January 1, 1999
                • 1553
                Re: C1 Gasket
                Dennis,
                I have pulled several known originals draft tubes off of engines and have found a gasket not only between the block and tube but also between the bolt and the tube. They were both paper gaskets and Dr Rebuild sells a grey paper gasket set that replicates both quite well. I cannot speak to the 62 cars that had a fitting and the PCV valve, but would assume that since eariler models used them, that the 62 would use tham as well. The Aim does not show the gaskets, but they were used.
                Regards, John McGraw
                • Dennis C.
                  • January 1, 1984
                  • 2409
                  Re: C1 Gasket
                  Thanks very much John. Assume the jury must still be out on this issue. Dennis
                  • Clem Z.
                    • January 1, 2006
                    • 9427
                    Re: C1 Gasket
                    just a wild ass guess how about a distributor to manifold gasket for the correct size? i have not looked at a road draft tube block since the 60s becaused we destroyed them pretty fast and were always looking for a new block so they never lasted very long.
                    • Mike M.
                      • May 31, 1974
                      • 8385
                      Re: C1 Gasket
                      why not make the two gaskets?
                      • Dennis C.
                        • January 1, 1984
                        • 2409
                        Re: C1 Gasket
                        Clem, thanks, but the two gaskets share no common dimension. Wish they did. DC
