1980 Lo Beam Guide Replacement Lights - NCRS Discussion Boards
  • Bob S.
    • December 1, 1994
    • 6
    I was wondering if anyone could give me a source for the oem Guide Low beam and I guess the GE Halogen high beam headlights for a 1980 coupe.
    Thanks for your help.
    • 43240
    Re: 1980 Lo Beam Guide Replacement Lights
    Bob------
    As far as I know, Guide headlamps are no longer manufactured. At the time of your car's manufacture, Guide was a division of GM (i.e. the Inland-Fisher-Guide Division). In the mid-1990's, the "Guide" component of that division was "spun-off" as an independent company. However, I believe that they ceased manufacturing headlamps even prior to that event. There are reproduction sources of the Guide lamps, but I don't think that the configuration that existed in 1980 are reproduced (Guide-manufactured headlamps changed lens configuration MANY times over the years of their manufacture).
    As far as GE-manufactured halogen high beams, I didn't realize that brand or type was ever originally used for 1980 Corvettes. If that's the case, someone may have added these later. In any event, GE-brand bulbs should not be difficult to locate. GE-brand and Sylvania-brand are the most common brands which can be found in auto parts stores. The configuration of today's GE sealed beams may differ somewhat, though, from the ones you have.
    • Jack H.
      • April 1, 1990
      • 9906
      They show up NOS on eBay quite frequently. Had a set (Guide low beams) that went begging without buyer(s) at $5/pair. Finally gave them to a fellow club member to unclutter my shelf....
